https://youtu.be/o5u1JcKtItU
Patch Fixtures, Wanted to Patch all on Universe 2.
if use Auto Patch, and move the fixtures - it does not follow correctly.
ESAPRO2 - Patch Bug
Re: ESAPRO2 - Patch Bug
So, the automatic patch feature will always try to patch all your fixtures from the first available address, regardless the current universe you're on in the patch window.
What you need to do if you want to patch all your fixture from a given start address is to :
- set the start address of your first fixture,
- select all your fixtures,
- press "patch"
This will patch all your fixtures one after the other, starting atthe set address.
Hope this helps.
- press "patch"
Hope this helps.
Ok, I understand that.
However how do you explain the random gap in the adjustment of the Patching?
Indeed, this part is a stupid bug and needs fixing. I had missed it in your video. Thanks for your feedback !
