I have never click the "protection" option before and accidentally clicked it. Now I can't do anything. Even closing the show and opening it back it is still in protect mode. Is there ANY sort of default password or way to reset the password? I have a show tonight and am super screwed without this...
Thanks!
-David
URGENT: Sunlite Suite 2 PASSWORD??
Re: URGENT: Sunlite Suite 2 PASSWORD??
Hi David,
If you have the latest version of the software then clicking on the Protections button top left when on the Controller tab should disable it and get your functions back.
If you are using an older version of Sunlite Suite 2 then you will need to ctrl click the Protections button to disable the lock.
Hope that helps.
Hope that helps.
Thank you for the reply. The problem is that it ask for a password and I never set a password. If one is set then it was set by someone who was not supposed to be on this computer but as far as I know that has never happened. PLEASE HELP. Any advise is greatly appreciated!
-David
-David
More than 6 months later... you don't use sunlite very often.
We can't tell you how to hack the password protection because... it's a password protection.
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
Hi David,
Please read the Access Privileges part of the user manual which should help.
http://manuals.nicolaudie.com/en/343-39 ... Sb9Aj6.htm
THANKS SO MUCH! THAT WORKED!!
