I do not know if anyone is going to answer me, but here is my problem
Simple example:
In a page I have 10 par64
I create a first switch that turns the first 5
I create a 2nd switch that turns the last 5
I turn my two switches
and then I create a switch, in the same page, using the state of the first switch (on) and 2nd (on)
The switch is created, but it is false, sunlite does not take into account the two switches activated, only one
Is this a bug? are there any solution t
thank you
In the same page, create switch, using the state of oder sw
Re: In the same page, create switch, using the state of oder
I can't reproduce this issue. Check that the channels at 0% are set to OFF and not set to DIMMER. If this is set up correctly and it still isn't working, send me your show and let me know which buttons are not being recorded correctly when you make a button with 'as you see now'
thank you for your reply
with other channels OFF it works.
My question was not well formulated.
switch1:
I have an effect on all channels
switch2:
all channels to 50%
When I activate the two switches, it works. (50% on :all channels + effect)
it is not possible to create a switch 3rd with the first two
(in the same page).
That's what I can not do
thank you
David
switch1:
switch2:
all channels to 50%
(in the same page).
thank you
David
