Hi Simon,
This time I have an even bigger issue.
I installed the software on my win7-64 laptop which my controller is connected.
If I start up the ‘tool’ software, I can connect and update to firmware 1.20
However, if I start up the 1 july suite, then I can’t connect to the controller.
I tried to uninstall usb drivers and reinstall, but nothing worked.
I also installed an older suite2 version, and there I had connection, but because the controller is now updated, the older suite soft doesn’t work with it .
Is there any logs I can give to you?
To me it seems that there is something wrong with usb connection with suite2 software.
Can you check this?
USB connection doesn't work on 1 july release
Re: USB connection doesn't work on 1 july release
It's solved with the new beta.
Thanks.
Thanks.
Hello together;),
i have the same issue with this version; also with the new beta. After the downgrade to the dec 12 version, it is working.
I use the Win7-64.
Has anybody an solution?
Thank You
Chris
I use the Win7-64.
Thank You
Chris
Make sure you have the latest firmware included with the latest version
Try adding the interface manually instead of using auto detection
If it's still not working, e-mail me a screenshot of the first page of tools
