White channel adjustment problems
Thank you Simon for this release. I have a problem with RGBW led projectors. I put in the scaneditor model a channel white amber for the white channel, and in the tricromie switch I have this functions which automatically increasde the white channel for pastel color, but i cant find the same function in the palette editor tricromie (note possible to make palette using the white channel) and also not present in the tricromie of easytimes effects. Do I miss something ?
Re: White channel adjustment problems
Generic palettes only allow the setting of RGB, however a palette per fixture type will allow you to set the White channel
Rects don't currently support RGBW. This is actually coming in the next beta. For now, you must apply the EasyTime effects directly on the lighting fixtures
