I have been experiencing occasional crashes while playing back a cycle containing a video. The cycle is in the format AVI#VIDEO_NAME. When it happens the screen just freezes (stuck on the current frame of the video) and I have to kill Sunlite and restart it. I have looked in the directory and there is no DMP file created. I'm running the June 8, 2010 version with a SL512BC box running 1.15 firmware. The box is also called SIUDI-6C in Tools. Any ideas what could cause this?
Thanks in advance for any help!
Crash when playing back Video Cycle (AVI#)
Re: Crash when playing back Video Cycle (AVI#)
would it be possible to upload your video anywhere so we can give it a test?
Is there any pattern as to when it crashes or does it appear to be random?
It's somewhat random. We play 3 40 minute sets of material in the same club every Thursday. There have been some shows where the crash doesn't happen at all. If it does happen it's usually only once per night. Here's all of the specs of the video that crashed most recently:
General
Complete name : D:\Users\Craig\Desktop\Johnny Drama\JDTV FINALS\DJmedley9_15.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 77.0 MiB
Duration : 13mn 33s
Overall bit rate : 794 Kbps
Encoded date : UTC 2010-09-16 07:15:37
Tagged date : UTC 2010-09-16 07:15:37
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 13mn 33s
Bit rate mode : Variable
Bit rate : 599 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Bottom Field First
Bits/(Pixel*Frame) : 0.058
Stream size : 58.1 MiB (75%)
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 13mn 33s
Bit rate : 192 Kbps
Maximum bit rate : 301 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Stream size : 18.4 MiB (24%)
Language : English
If it's ok I'd like to PM a link to the video (it's content that I'd like to not have in the wild) Also if it helps the laptop is running Windows 7 32 bit and FFDshow is being used to decode the H.264 and AAC audio within the video.
General
Format : MPEG-4
Codec ID : mp42
Duration : 13mn 33s
Video
Format : AVC
Codec ID : avc1
Duration : 13mn 33s
Bit rate : 599 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 13mn 33s
Bit rate : 192 Kbps
Language : English
