Hi Sunliters,
I recently installed the latest version of Sunlite (29th May 2009), but discovered when I used it for the first time, all the MIDI command mappings that allow me to use a BCF2000 controller had vanished. This may be a consequence of overlaying a new version on top of an existing install, but it was a bit unfortunate!! All the other aspects of my existing pages were OK, so I wonder why the MIDI mappings were affected specifically.
Is there anyway to back up the MIDI part of the page configuration, or should it have been stored when I archived the page (which I do regularly)?
I also found that the specific MIDI commands I had set up in the EasyConsole to match my BCF2000 config had gone, but I assume that is because I had made changes to the standard console template, and did not save it with a different name. Therefore the upgrade overlaid the standard template, wiping out my modifications. A warning for anyone planning to upgrade!!
Cheers, Vince
Saving MIDI mapping for Sunlite pages?
Re: Saving MIDI mapping for Sunlite pages?
yes you need to save the show before upating version.
We do our best to change this in next version to unchange existing file of console.
------- Dylan --------
