LED uplights
each half placed on each side of a room.
whats the easiest way to create
1)
a sequence or show where one fixture on each side has got the same colour.
AND
2)
a sequence where examble two fixtures are running first on one side the on the other "like the clock big ben".
I started creating groups for each pair.
then create switches for each combination of group and colour, but that can create a huge amount of switches ...
so a good idea is needed.
can I use the sequencing numbering inside a group ... and how ?
tia
steen
advice needed : koordination of fixtures examble pairs each
Re: advice needed : koordination of fixtures examble pairs e
Sorry... i don't understand what you want to do...
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
Hi
wasn't easy to write as well ... :-(
Ok, I got an idea to explain it a different way :
fixture placement :
===== wall =====
x1 x2 x3 x4 x5 x6
people ...
y1 y2 y3 y4 y5 y6
===== wall =====
I want to make sure that I control x1 and y1 and the same time.
( x1,y1 ) turns blue ( x2,y2 ), then (x3,y3 ) ....
and
that Im able to create a run which turns ... ( x4, x5 ) red, then ( x5,x6 ) then ( x6,y1 ) then ( y1,y2 ) ...
My first idea was to create groups ( x1,y1 ), ( x2, y2 ) ( x3, y3 ) ...
And then create switches for each colour I wanted to use but ... that means many switches.
I hope this is possible to understand.
I had a thought that numbering inside a group could help but if I :
create numbering
x1,y1,x2,y2,x3,y3 ...
Then If I choose easytime, chaser effect, it wont work because I can't change "the step length".
the chaser ( size 2 ) lights up :
(x1,y1),
then (y1,x2) ( which I dont want ),
( x2,y2 ) Ok,
( y2,x3 ) ( which I dont want ),
TIA
Steen
fixture placement :
===== wall =====
x1 x2 x3 x4 x5 x6
people ...
y1 y2 y3 y4 y5 y6
===== wall =====
and
create numbering
(x1,y1),
( x2,y2 ) Ok,
TIA
Steen
Okkkkk !!!!! :)
You have to work with "Fixture Order" in "Easy Time" and create as many profiles you want.
So you will be able to chase in any order you want simply by choosing the good order profile.
But... it's very difficult to explain by text... just try it ;)
The link is a test show using "Fixture Order" to make what i understand about your problem.
https://www.dropbox.com/s/wp96v7eeszzgc ... t.shw?dl=0
Gael
Gael
Gaël Rambaud
*** Freelance ***
*** Freelance ***
got it :-)
I dont think that it easy to find ... video could be nice ...perhaps I will start making some ...
thanks
Steen
thanks
Steen
