problem with easy view
Postby mark » Mon May 09, 2005 3:27 pm
I have ver mar 29 2005 and when I want to go to stage settings i get Error
Could not load mesh from specified file. What is wrong?? I also reinstall all programs without any luck. Anybody know what is wrong.
mark
Postby mark » Tue May 10, 2005 1:51 pm
I just solve the problem with help of Marc. Don't blame OS or try to reinstall it doesn't help. You have to change easyview.exe with new one. I hope they will put on download site soon.
mark
Postby azestrada » Fri Jul 28, 2006 4:45 pm
I have the same problem, where can I find the new easyview.exe file. thank you
azestrada
Postby Guest » Mon Jul 31, 2006 8:47 am
Dowload the sofware from our website
Guest
Postby azestrada » Tue Aug 01, 2006 1:09 pm
Hi, I donwloded the last version of sunlite 2004 and all easyview works except when I want edit the stage (when I press the contruction button).
azestrada
Postby azestrada » Fri Aug 04, 2006 8:49 pm
Please I need help with this problem, I already intalled the new sunlite 2004 and I have the same problem when I pressed the contruction buttom
Thank you
azestrada
Postby Marc » Tue Aug 08, 2006 1:01 pm
It seems that some objects are not supported by all the graphic cards.
Try to create an empty EasyViewLibrary Folder (Rename the old one) and add only supported objects.
Send me an email if it doesn't work. We have to find a PC where this problem appears to fix it.
thanks for playing...
Marc
Postby azestrada » Wed Aug 16, 2006 2:43 pm
Hi Marc, thanks for your help. If I use a empty space I can get in to construction settings but if I add any object or fixture the problem appears again.
azestrada
Return to Legacy Products
Who is online
