Your interface will be compatible with Sunlite Suite and Easy Stand Alone. You can use sound to light in Sunlite Suite. You may find the Sunlite Suite getting started video tutorials helpful
http://www.nicolaudie.com/tutorials/suite-You are using an economy class interface therefore Easy Show is not compatible
-The 3D visualiser will work in LIMITED MODE
If you are a total beginner I would advise you take a look at Easy Stand Alone first. It is very basic and what you can do is limited but it is a good software to start with as it helps you understand the basics of patching fixtures, creating effects, viewing your lighting in 3D etc..
